How F5 NGINX One Enhances Management and Observability
NGINX | October 10, 2024
As the number of applications across hybrid and multicloud enterprise environments increases, the need for effective management, security, and observability of these applications has become more pressing than ever. F5 NGINX One is designed to address these challenges by offering a unified solution for monitoring, managing, and securing modern application infrastructures. By simplifying the way organizations manage their NGINX instances (both F5 NGINX Plus and Open Source instances), NGINX One ensures that all teams across the enterprise—including Platform, Security, NetOps, and DevOps teams—can maintain real-time visibility into performance, security, and compliance across all environments, ultimately enhancing efficiency and reducing operational complexity.
Streamlined operations
NGINX One revolutionizes the way organizations manage their NGINX deployments by providing a centralized SaaS-based web console. This eliminates the need for manual configuration and updating tasks, such as emailing teams, waiting for responses, or running network scans to understand NGINX usage and versions. Before NGINX One, users had to go through the cumbersome process of obtaining IP addresses, SSH access, and root permissions just to view or modify configurations.
NGINX One makes staging configuration updates simple through a side-by-side visual difference (diff) view. Users can clearly see the impact of their changes before publishing without leaving the console. This eliminates the need for direct server access and simplifies the entire configuration management process. While not a full replacement for GitOps, NGINX One saves a small number of diffs of configuration changes, allowing for easy rollbacks when needed. NGINX One’s API enables programmatic configuration changes, facilitating integration with existing pipelines and workflows.
Unified management and collaboration
NGINX One transforms collaboration by offering a graphical user interface console that visually presents easy-to-grasp representations of complex text-based NGINX configuration files. This intuitive interface simplifies cross-functional collaboration sessions, making it easier for managers and developers to understand and make decisions. Developers retain the ability to access fine-grained text configurations within the console, ensuring detailed control without sacrificing the benefits of a unified interface.
The clustering feature, or sync groups, streamlines the management of multiple NGINX instances behind a load balancer. By adding NGINX instances to a sync group, users can apply configuration changes simultaneously across all instances. This ensures consistency and eliminates the need for manual synchronization or external automation tools, saving time and reducing the risk of misconfigurations.
NGINX One product dashboard
NGINX One Dashboard
Real-time visibility and insights
NGINX One provides out-of-the-box visibility into crucial application and system metrics such as CPU, memory, disk space, and network traffic, eliminating the need to invest in separate monitoring systems. Layer 7 insights, including the number of failing HTTP connections, are readily available without the need for manual log analysis or custom dashboards. Previously, users needed to access each instance individually for insights. NGINX One brings this information to the forefront, making it easily accessible.
Recommendations based on configuration, performance, security, and operational best practices are provided across the entire NGINX fleet. The total number of recommendations and security-specific recommendations are prominently displayed on the first dashboard, giving managers an easy-to-access, high-level view of any issues. While recommendations are currently generated based on a static list of best practices, NGINX is actively working to implement AI-powered recommendations. By analyzing well-performing instances and comparing them to underperforming ones, the platform will provide tailored suggestions for optimization.
Automated compliance and security
NGINX One takes the burden of compliance and security off the shoulders of teams and team leaders. It automates compliance checks by displaying vulnerabilities and remediation steps directly in the console. This eliminates the need for costly third-party vulnerability scanners and simplifies the process of upgrading and patching, ensuring organizations stay current with security best practices.
Looking ahead, NGINX One will introduce automated policy enforcement through templates. Super admins will have the ability to create templates with predefined options and limited customization. This feature will ensure consistent and compliant configurations across the organization, reducing the risk of human error and enhancing an organization’s security posture.
Simplified licensing and support
NGINX One simplifies the licensing and support process by consolidating multiple SKUs into a single, easy-to-buy offering—enterprises only need to choose between standard or premium support, and if they want to have F5 NGINX App Protect WAF. This streamlined approach reduces the complexity of purchasing and renewal processes, particularly for large organizations with intricate procurement workflows. Customers gain clarity on what they need and what's included in their subscription.
The simplified licensing model accelerates deployment and adoption by minimizing friction in the procurement process. This is particularly valuable for large enterprises that have grown through mergers and acquisitions, where multiple purchasing departments may be involved.
Removing the complexity from hybrid, multicloud environments
In the current era of application delivery, the focus has to be on more flexible, software-defined approaches designed to oversee complex hybrid and multicloud application environments. Traditional Application Delivery Controllers (ADCs) evolved from hardware appliances in data centers to cloud-native services, and now to comprehensive platforms for hybrid, multicloud environments that can handle the complex needs of AI workloads. NGINX One embodies this shift by offering advanced management, security, and observability capabilities that empower enterprises to efficiently manage their NGINX instances, gain real-time visibility into performance metrics, and ensure compliance and security across their application delivery infrastructure. By providing a centralized SaaS-based web console, unified management capabilities, and deep insights into application behavior, NGINX One makes the complex task of overseeing modern application delivery in hybrid and multicloud environments simple.
Want to see the management and observability capabilities of F5 NGINX One in action? Watch these product demos on DevCentral for a quick walkthrough of how the SaaS-based web console enables teams to monitor certificates and CVEs, edit and update configurations, and synchronize settings across multiple instances with the Config Sync Group feature.
NGINX | 10/05/2022
NGINX | 05/26/2022
NGINX | 12/09/2021
NGINX | 01/20/2021
NGINX | 12/15/2015
NGINX | 01/01/2014
How F5 NGINX One Enhances Management and Observability | F5
