Top Risks
Sensor Intel Series: Top CVEs in March 2024
TP-Link Archer AX21 Wifi Router targeting, plus a handful of new CVEs! See what mass scanning looks like in March 2024.
April 30, 2024
7 min. read
Previous article in this series
Next article in this series
The Sensor Intel Series is created in partnership with Efflux, who maintains a globally distributed network of sensors from which we derive attack telemetry.
Introduction
Welcome to the March 2024 installment of the Sensor Intelligence Series, our monthly summary of vulnerability intelligence based on distributed passive sensor data. This month’s attack data had one really big difference from what we usually see – we added a signature for CVE-2023-1389 and found that it was our top scanned for vulnerability and had been on the rise for the last several months!
Newly tracked vulns include:
  • CVE-2023-1389, a command injection vulnerability in the firmware for the TP-Link Archer AX21 Wi-Fi router (CVSS 8.8, EPSS 92.7%)1
  • CVE-2009-3960, an unspecified information disclosure vulnerability in the BlazeDS 3.2 library used by several Adobe products (CVSS v2 4.3, EPSS 99.68%)2
  • CVE-2014-9792, a privilege escalation vulnerability in a Qualcomm component for Android devices (CVSS 7.8, EPSS n/a)3
  • CVE-2020-28188, a remote code execution vulnerability in the TerraMaster TOS software. We already have been tracking this, but we added a new signature for another vector for exploiting this. (CVSS 9.8, EPSS 99.9%)4
  • CVE-2022-47945, a local file inclusion vulnerability in the ThinkPHP framework (CVSS 9.8, EPSS 92%)5
March Vulnerabilities by the Numbers
Figure 1 shows March attack traffic for the top ten CVEs that we track. Note the emergence of CVE-2023-1389 at the top. Once we found a good signature for this vulnerability, we found that it’s activity pattern over the last year had been quite low, but present, in 2023, and suddenly jumped by several orders of magnitude in the last three months. Clearly, someone is targeting this WiFi router bug quite intentionally, likely to build out a bot net or other attacker infrastructure.
Our other top 10 entries are all ones we’ve seen before and are not showing a huge amount of variability.
Top 10 CVEs for Ports 80/443, March 2024
Figure 1. Top ten vulnerabilities by traffic volume in March 2024. CVE-2023-1389 has emerged as our top scanned vulnerability.
Who is Scanning for CVE-2023-1389?
When we see such a distinct increase in scanning activity for a particular CVE, the next question is usually to figure out who is scanning for it, and where they’re targeting thier scans. Sometimes, we see a wide variety of IPs and source countries, and other times we see activity coming from a smaller subset of ASNs.
In this case, just two ASNs are generating the majority of the activity. The following chart shows the distribution of source ASNs for scans targeting CVE-2023-1389.
Source ASNs Scanning for CVE-2023-1389, March 2024
Figure 2. Distribution of source ASNs for scanning traffic targeteing CVE 2023-1389. "All Others" includes 33 ASNs.
Meanwhile, the scans are distributed across a wide range of target countries:
The majority of the scanning activity is coming from IP addresses assigned to just a handful of ASNs, mostly AS49870 (Alsycon, a hosting provider out of the Netherlands) and AS47890 (Unmanaged Ltd, what looks to be an IT consulting firm based out of the UK). The scanners appear to be using VPS or other resources at these firms to conduct their activity.
After normalization for the number of sensors and other factors, the scanning activity looks to be quite evenly distributed across all the target countries listed above, each receiving approximately 3% of the total traffic, indicative of scanning casting an internet-wide net and attempting to find, in this case, as many vulnerable Wifi routers as possible.
Traffic Volume for Everything Else
Leaving the top ten, Table 1 shows traffic volumes for all vulnerabilities that we’re tracking, along with change from the previous month, CVSS score, and EPSS score. This month we’ve continued to include percent change in addition to the raw change. In terms of high-traffic CVEs, the percent change is usually more instructive. In terms of low-traffic CVEs where a fluctuation of a handful of connections makes for a change of hundreds of percent, raw traffic is more useful.
CVE Number March Traffic Change from February Percent Change CVSS v3.x EPSS Score
CVE-2023-1389 3866 350 10.0% 8.8 0.92697
CVE-2020-11625 2688 -1044 -28.0% 5.3 0.46366
CVE-2022-24847 2377 47 2.0% 7.2 0.39902
CVE-2017-9841 2349 -206 -8.1% 9.8 0.99963
CVE-2022-22947 1876 -56 -2.9% 10 0.99973
CVE-2022-42475 1171 -6 -0.5% 9.8 0.9724
CVE-2020-8958 842 -695 -45.2% 7.2 0.98143
CVE-2022-41040/CVE-2021-34473 547 -104 -16.0% 9.8 0.99604
CVE-2021-3129 376 -327 -46.5% 9.8 0.99956
CVE-2020-0618 369 -34 -8.4% 8.8 0.99929
CVE-2021-28481 316 -160 -33.6% 9.8 0.92242
CVE-2018-13379 244 163 201.2% 9.8 0.99924
Citrix XML Buffer Overflow 222 -23 -9.4% NA n/a
CVE-2014-2908 221 -21 -8.7% NA n/a
CVE-2021-44228 186 -277 -59.8% 10 0.99998
CVE-2021-40539 140 -44 -23.9% 9.8 0.99977
CVE-2019-18935 139 -47 -25.3% 9.8 0.98961
CVE-2019-9082 134 -100 -42.7% 8.8 0.9995
CVE-2018-10561 128 22 20.8% 9.8 0.99773
CVE-2022-40684 122 122 0.0% 9.8 0.99792
2018 JAWS Web Server Vuln 94 54 135.0% NA n/a
CVE-2017-1000226 93 -84 -47.5% 5.3 0.37937
CVE-2021-26855 93 -50 -35.0% 9.8 0.99981
CVE-2021-26086 91 -84 -48.0% 5.3 0.98875
NETGEAR-MOZI 82 -9 -9.9% NA n/a
CVE-2020-25506 74 68 1133.3% 9.8 0.99903
CVE-2019-1653 66 -27 -29.0% 7.5 0.99999
CVE-2018-9995 59 -60 -50.4% 9.8 0.98747
CVE-2017-18368 48 46 2300.0% 9.8 0.99987
CVE-2022-47945 47 -172 -78.5% 9.8 0.92006
CVE-2014-2321 33 6 22.2% NA n/a
CVE-2017-10271 18 -31 -63.3% 7.5 0.99934
CVE-2019-12725 9 -44 -83.0% 9.8 0.9952
CVE-2020-9757 8 8 0.0% 9.8 0.9958
CVE-2020-17496 7 1 16.7% 9.8 0.99968
CVE-2020-5902 7 -2 -22.2% 9.8 0.99998
CVE-2018-17246 6 6 0.0% 9.8 0.99618
CVE-2018-7600 6 -8 -57.1% 9.8 1
CVE-2019-2725 6 3 100.0% 9.8 1
CVE-2019-9670 6 5 500.0% 9.8 0.99968
CVE-2022-22965 6 0 0.0% 9.8 0.99973
CVE-2007-3010 5 5 0.0% NA n/a
CVE-2020-25078 5 -61 -92.4% 7.5 0.98335
 CVE-2020-28188 4 1 33.3% NA n/a
CVE-2018-7700 4 4 0.0% 8.8 0.97473
CVE-2020-3452 4 4 0.0% 7.5 0.99981
CVE-2021-21985 4 1 33.3% 9.8 0.99921
CVE-2021-26084 4 -70 -94.6% 9.8 0.99946
CVE-2022-21587 4 1 33.3% 9.8 0.99881
CVE-2014-6287 2 -43 -95.6% 9.8 n/a
CVE-2015-8813 2 2 0.0% 8.2 0.76191
CVE-2017-0929 2 2 0.0% 7.5 0.80646
CVE-2017-17731 2 2 0.0% 9.8 0.895
CVE-2018-1000600 2 2 0.0% 8.8 0.9902
CVE-2018-20062 2 0 0.0% 9.8 0.9963
CVE-2019-12988 2 -1 -33.3% 9.8 0.99842
CVE-2019-16057 2 -4 -66.7% 9.8 0.99986
CVE-2019-8982 2 2 0.0% 9.8 0.87753
CVE-2020-24949 2 2 0.0% 8.8 0.99339
CVE-2021-27065 2 2 0.0% 7.8 0.99524
CVE-2023–25157 2 -1 -33.3% 9.8 #N/A
CVE-2020-15505 1 -2 -66.7% 9.8 0.99992
CVE-2005-3128 0 0 0.0% NA n/a
CVE-2008-2052 0 0 0.0% NA n/a
CVE-2008-6668 0 0 0.0% NA n/a
CVE-2009-1872 0 0 0.0% NA n/a
CVE-2011-4926 0 0 0.0% NA n/a
CVE-2012-1823 0 0 0.0% NA n/a
CVE-2012-4940 0 0 0.0% NA n/a
CVE-2013-6397 0 0 0.0% NA n/a
CVE-2014-4535 0 0 0.0% 6.1 n/a
CVE-2014-9792 0 -34 -100.0% 7.8 n/a
CVE-2015-3897 0 0 0.0% NA 0.98358
CVE-2015-4074 0 0 0.0% 7.5 0.78003
CVE-2016-1000149 0 0 0.0% 6.1 0.45187
CVE-2016-4945 0 0 0.0% 6.1 0.57722
CVE-2017-11511 0 0 0.0% 7.5 0.9694
CVE-2017-11512 0 0 0.0% 7.5 0.99796
CVE-2017-9506 0 0 0.0% 6.1 0.77543
CVE-2018-18775 0 0 0.0% 6.1 0.50454
CVE-2018-20463 0 0 0.0% 7.5 0.90846
CVE-2019-12987 0 -3 -100.0% 9.8 0.99842
CVE-2019-2588 0 0 0.0% 4.9 0.95728
CVE-2019-2767 0 0 0.0% 7.2 0.95687
CVE-2020-0688 0 0 0.0% 8.8 0.99896
CVE-2020-13167 0 -3 -100.0% 9.8 0.99919
CVE-2020-17453 0 0 0.0% 6.1 0.81798
CVE-2020-17505 0 0 0.0% 8.8 0.9945
CVE-2020-17506 0 0 0.0% 9.8 0.99442
CVE-2020-22211 0 0 0.0% 9.8 0.96264
CVE-2020-25213 0 -4 -100.0% 9.8 0.99912
CVE-2020-27982 0 0 0.0% 6.1 0.64562
CVE-2020-28188 0 -3 -100.0% 9.8 0.99856
CVE-2020-7796 0 0 0.0% 9.8 0.97966
CVE-2020-7961 0 -6 -100.0% 9.8 0.99959
CVE-2020-9344 0 0 0.0% 6.1 0.57856
CVE-2021-20167 0 0 0.0% 8 0.99229
CVE-2021-21315 0 0 0.0% 7.8 0.99826
CVE-2021-21801 0 0 0.0% 6.1 0.98225
CVE-2021-23394 0 -3 -100.0% 9.8 0.87221
CVE-2021-25003 0 -3 -100.0% 9.8 0.97734
CVE-2021-25369 0 -3 -100.0% 6.2 0.44972
CVE-2021-29203 0 0 0.0% 9.8 0.99322
CVE-2021-31589 0 0 0.0% 6.1 0.6825
CVE-2021-32172 0 -3 -100.0% 9.8 0.96666
CVE-2021-33357 0 -3 -100.0% 9.8 0.99572
CVE-2021-33564 0 -6 -100.0% 9.8 0.94009
CVE-2021-3577 0 0 0.0% 8.8 0.99459
CVE-2021-38702 0 0 0.0% 6.1 0.8259
CVE-2021-41277 0 -3 -100.0% 10 0.99367
CVE-2022-0653 0 0 0.0% 6.1 0.57952
CVE-2022-0885 0 -3 -100.0% 9.8 0.96749
CVE-2022-1040 0 -3 -100.0% 9.8 0.99939
CVE-2022-22954 0 0 0.0% 9.8 0.99941
CVE-2022-26134 0 -5 -100.0% 9.8 0.9999
CVE-2022-35914 0 -3 -100.0% 9.8 0.99914
CVE-2022-40734 0 0 0.0% 6.5 0.93965
CVE-2023-25651 0 0 0.0% 8 0.05456
Table 1. CVE targeting volumes for March, along with change from February.
Figure 3 is a bump plot showing the change in traffic volume and position over the last twelve months. This shows very clearly the increase in scanning for CVE-2023-1389 since the start of the year. Also notable is the decrease in CVE-2020-11625, which had been in the top spot the last few months.
Figure 3. Evolution of vulnerability targeting in the last twelve months. Note the huge increase in scanning for CVE-2023-1389.
Figure 4 shows traffic for the top 19 CVEs by all-time traffic, followed by a monthly average of the remaining CVEs. This once again shows the dramatic increase in CVE-2023-1389, as well as the recent peaks of CVE-2020-11625.
Figure 4. Traffic volume by vulnerability. This view accentuates the recent growth in CVE-2023-1389.
Conclusions
We were able to identify much increased scanning traffic for CVE-2023-1389 and 3 other CVEs this month, as well as a better identification for one we already tracked, CVE-2020-28188. We continue to see much of this sort of bulk scanning traffic primarily being directed to what can be loosely called IoT devices, including WiFi routers. It’s quite clear to us that this is mainly a means for attackers to gather deniable infrastructure, which is unlikely to be shut down due to complaints to ISPs. The second most common pattern we see is targeting of what might be called “traditional server software” – and judging from the payloads we observe in these exploitation attempts, this too is often directed towards building out botnets (Mirai, Mozi) and occasionally the installation of other DDoS and crypto-mining bots.
Recommendations
Technical
Preventative
  • Scan your environment for vulnerabilities aggressively.
  • Patch high-priority vulnerabilities (defined however suits you) as soon as feasible.
  • Engage a DDoS mitigation service to prevent the impact of DDoS on your organization.
Technical
Detective
  • Use a WAF or similar tool to detect and stop web exploits.
  • Monitor anomalous outbound traffic to detect devices in your environment that are participating in DDoS attacks.
Authors & Contributors
Malcolm Heath (Author)
Principal Threat Researcher
Footnotes
1https://nvd.nist.gov/vuln/detail/CVE-2023-1389
2https://nvd.nist.gov/vuln/detail/CVE-2009-3960
3https://nvd.nist.gov/vuln/detail/CVE-2014-9792
4https://nvd.nist.gov/vuln/detail/CVE-2020-28188
5https://nvd.nist.gov/vuln/detail/CVE-2022-47945
Read More from F5 Labs
Campaign Targets Amazon EC2 Instance Metadata via SSRF
04/08/2025 article 5 min. read
2025 Advanced Persistent Bots Report
03/28/2025 report 40 min. read
Why Critical MongoDB Library Flaws Won't See Mass Exploitation
03/13/2025 article 6 min. read
