Some folks seem to be conflating LLMs with AI agents. Let’s just put that to bed, shall we? While certainly some are “extending” chatbots to execute tools and call them AI agents, that’s an immature approach if you want to harness agents for advanced automation. Which of course you do, because you recognize that that’s one of the most valuable use cases to address the growing operational fatigue caused by hybrid, multicloud complexity.
An AI agent should be a software unit (an application) bounded system that interprets goals, maintains context, and performs actions by invoking tools. It may use a large language model (LLM) to reason about what needs to happen, but the LLM is just one piece of the machinery. The agent is the system.
In practical terms, an AI agent receives a task (explicit or inferred), evaluates it within a contextual boundary, and decides how to act. Such actions can include calling tools, querying systems, or triggering workflows.
Now, you don’t need a swarm of agents to get value out of one. A well-scoped, single agent tied to a tight toolchain can do useful work today. It can automate summaries, generate reports, classify tickets, or even shepherd alerts to the right queues. As long as it respects scope and policy, it’s already valuable.
You can use AI agents without doing Agentic AI. But once agents collaborate, you are doing agentic AI, even if your architecture isn't ready for it.
Based on our most recent research, I assume you’re either already dealing with agentic behavior (9% of respondents) or headed there (79% of respondents). Agentic AI requires a framework built around controlled execution in which multiple agents (yes, “minions,” because that makes it easier to distinguish from agentic AI) interact with shared tools, contextual goals, and enforcement layers like MCP.
An agent is a software construct that operates autonomously or semi-autonomously within clearly defined constraints. It interprets tasks, manages context, invokes tools, and makes decisions on behalf of a user or a larger system. In MCP-aligned architectures, agents conform to a structured protocol that governs how tasks, state, and policy interact.
Agents can reason, delegate, and act—but only within the sandbox they’ve been given. They don't improvise system calls. They don't invent tool access. Every action should pass through a declared interface that can be secured, monitored, and revoked.
At minimum, an agent has:
An LLM thinks. An agent acts. The platform governs.
There are two prevailing models, and one of them is a trap.
There are two prevailing approaches to constructing AI agents today: LLM-centric and Application-bounded. LLM-centric are appropriate for chatbots but not for more serious automation use cases.
This is the default for most frameworks today: LangChain, AutoGen, CrewAI, etc. The agent is essentially a chat prompt with injected tools and optional memory—wrapped around a single LLM session.
Limitations:
In short: it’s a smart intern with root access and no supervision. Works great, until it doesn't.
This is the model you want in production.
Here, the agent is a full software service built on a framework that uses an LLM but doesn’t depend on it to handle execution.
This approach gives you version control, access logs, tool-level governance, and runtime isolation. It’s how you turn agents from toys into infrastructure.
When people design agents as if they’re intelligent personas, they instinctively reach for human-centric access models: role-based access control (RBAC), login tokens, user attributes, identity scopes. These make sense when you're dealing with a consistent human identity across a session. But agents don’t behave like that. They’re not users. They're executors. And that changes everything.
Agents shift roles as they operate. A single agent might act as a data retriever, then a planner, then a trigger for automation, often within the same session and under the same task umbrella. It doesn’t log in, grab a static token, and stay in one lane.
This is where traditional access control fails. RBAC assumes static roles. Attribute-based access control (ABAC) assumes fixed attributes. Session tokens assume consistent scope. None of that holds when agents are dynamic. Identity in agentic systems is functional, not personal.
That’s why governing agents requires shifting away from identity-based policy to execution-based policy. Every tool call must be validated in real time against the agent’s current task role, context state, and permitted scope. Policies live at the tool layer, not the authentication layer. Context blocks, not login sessions, carry the necessary metadata to enforce those policies. This is why we call this paradigm shift “Policy in Payload,” because the policy literally is in the payload.
Treat agents like agents. Govern them like software. And never forget: the LLM thinks, the agent acts, and the platform governs. Confuse those roles, and you're building a personality with admin rights and no memory of its last mistake.
The LLM thinks. The agent acts. The platform governs.
Stick to that, and you’ll build agent infrastructure that scales, secures, and survives contact with reality.
