A Guide to Choosing an Ingress Controller, Part 4: NGINX Ingress Controller Options
NGINX | September 27, 2021
Editor – This post is part of a 10-part series:
  1. Reduce Complexity with Production-Grade Kubernetes
  2. How to Improve Resilience in Kubernetes with Advanced Traffic Management
  3. How to Improve Visibility in Kubernetes
  4. Six Ways to Secure Kubernetes Using Traffic Management Tools
  5. A Guide to Choosing an Ingress Controller, Part 1: Identify Your Requirements
  6. A Guide to Choosing an Ingress Controller, Part 2: Risks and Future-Proofing
  7. A Guide to Choosing an Ingress Controller, Part 3: Open Source vs. Default vs. Commercial
  8. A Guide to Choosing an Ingress Controller, Part 4: NGINX Ingress Controller Options (this post)
  9. How to Choose a Service Mesh
  10. Performance Testing NGINX Ingress Controllers in a Dynamic Kubernetes Cloud Environment
You can also download the complete set of blogs as a free eBook – Taking Kubernetes from Test to Production.
According to the Cloud Native Computing Foundation’s (CNCF) Survey 2020, NGINX is the most commonly used data plane in Ingress controllers for Kubernetes – but did you know there’s more than one “NGINX Ingress Controller”?
A previous version of this blog, published in 2018 under the title Wait, Which NGINX Ingress Controller for Kubernetes Am I Using?, was prompted by a conversation with a community member about the existence of two popular Ingress controllers that use NGINX.
I kinda knew about the two different ingress controllers based on the container image locations I’ve seen but I don’t think I’ve seen someone from NGINX outright say it before now.
It’s easy to see why there was (and still is) confusion. Both Ingress controllers are:
  • Called “NGINX Ingress Controller”
  • Open source
  • Hosted on GitHub with very similar repo names
  • The result of projects that started around the same time
And of course the biggest commonality is that they implement the same function.
NGINX vs. Kubernetes Community Ingress Controller
For the sake of clarity, we differentiate the two versions like this:
  • Community version – Found in the kubernetes/ingress-nginx repo on GitHub, the community Ingress controller is based on NGINX Open Source with docs on Kubernetes.io. It is maintained by the Kubernetes community.
  • NGINX version – Found in the nginxinc/kubernetes-ingress repo on GitHub, NGINX Ingress Controller is developed and maintained by F5 NGINX with docs on docs.nginx.com. It is available in two editions:
    • NGINX Open Source‑based (free and open source option)
    • NGINX Plus-based (commercial option)
There are also a number of other Ingress controllers based on NGINX, such as Kong, but fortunately their names are easily distinguished. If you’re not sure which NGINX Ingress Controller you’re using, check the container image of the running Ingress controller, then compare the Docker image name with the repos listed above.
NGINX Ingress Controller Goals and Priorities
A primary difference between NGINX Ingress Controller and the Community Ingress controller (along with other Ingress controllers based on NGINX Open Source) are their development and deployment models, which are in turn based on differing goals and priorities.
  • Development philosophy – Our top priority for all NGINX projects and products is to deliver a fast, lightweight tool with long‑term stability and consistency. We make every possible effort to avoid changes in behavior between releases, particularly any that break backward compatibility. We promise you won’t see any unexpected surprises when you upgrade. We also believe in choice, so all our solutions can be deployed on any platform including bare metal, containers, VMs, and public, private, and hybrid clouds.
  • Integrated codebase – NGINX Ingress Controller uses a 100% pure NGINX Open Source or NGINX Plus instance for load balancing, applying best‑practice configuration using native NGINX capabilities alone. It doesn’t rely on any third‑party modules or Lua code that have not benefited from our interoperability testing. We don’t assemble our Ingress controller from lots of third‑party repos; we develop and maintain the load balancer (NGINX and NGINX Plus) and Ingress controller software (a Go application) ourselves. We are the single authority for all components of our Ingress controller.
  • Advanced traffic management – One of the limitations of the standard Kubernetes Ingress resource is that you must use auxiliary features like annotation, ConfigMaps, and customer templates to customize it with advanced features. NGINX Ingress Resources provide a native, type‑safe, and indented configuration style which simplifies implementation of Ingress load‑balancing capabilities, including TCP/UDP, circuit breaking, A/B testing, blue‑green deployments, header manipulation, mutual TLS authentication (mTLS), and web application firewall (WAF).
  • Continual production readiness – Every release is built and maintained to a supportable, production standard. You benefit from this “enterprise‑grade” focus equally whether you’re using the NGINX Open Source‑based or NGINX Plus-based edition. NGINX Open Source users can get their questions answered on GitHub by our engineering team, while NGINX Plus subscribers get best-in-class support. Either way it’s like having an NGINX developer on your DevOps team!
NGINX Open Source vs. NGINX Plus – Why Upgrade to Our Commercial Edition?
And while we’re here, let’s review some of the key benefits you get from the NGINX Plus-based NGINX Ingress Controller. As we discussed in How to Choose a Kubernetes Ingress Controller, Part 3: Open Source vs. Default vs. Commercial, there are substantial differences between open source and commercial Ingress controllers. If you’re planning for large Kubernetes deployments and complex apps in production, you’ll find our commercial Ingress controller saves you time and money in some key areas.
Security and Compliance
One of the main reasons many organizations fail to deliver Kubernetes apps in production is the difficulty of keeping them secure and compliant. The NGINX Plus-based NGINX Ingress Controller unlocks five use cases that are critical for keeping your apps and customers safe.
Learn how German automotive giant Audi secured their Red Hat OpenShift apps in Audi Future‑Proofs Tech Vision and App Innovation with NGINX.
Application Performance and Resiliency
Uptime and app speed are often key performance indicators (KPIs) for developers and Platform Ops teams. The NGINX Plus-based NGINX Ingress Controller unlocks five use cases that help you deliver on the promises of Kubernetes.
  • Get live monitoring – The NGINX Plus dashboard displays hundreds of key load and performance metrics so you can quickly troubleshoot the cause of slow (or down!) apps.
  • Detect and resolve failures faster – Implement a circuit breaker with active health checks that proactively monitors the health of your TCP and UDP upstream servers.
  • Reconfigure with zero restarts – Faster, non‑disruptive reconfiguration ensures you can deliver applications with consistent performance and resource usage and lower latency than the open source alternatives.
  • Thoroughly test new features and deployments – Make A/B testing and blue‑green deployments easier to execute by leveraging the key‑value store to change the percentages without the need for reloads.
  • Resolve support needs quickly – Confidential, commercial support is essential for organizations that can’t wait for the community to answer questions or can’t risk exposure of sensitive data. NGINX support is available in multiple tiers to fit your needs, and covers assistance with installation, deployment, debugging, and error correction. You can even get help when something just doesn’t seem “right”.
Learn how business text messaging company Zipwhip accomplished 99.99% uptime for their SaaS apps in Strengthen Security and Traffic Visibility on Amazon EKS with NGINX.
Next Step: Try NGINX Ingress Controller
If you’ve decided that an open source Ingress controller is the right choice for your apps, then you can get started quickly at our GitHub repo.
For large production deployments, we hope you’ll try our commercial Ingress controller based on NGINX Plus. It’s available for a 30-day free trial that includes NGINX App Protect.
Tags: 2021, Tech
About the Author
Jenn Gile
Jenn GileHead of Product Marketing, NGINX
More blogs by Jenn Gile
NGINX | 10/05/2022
NGINX | 05/26/2022
NGINX | 12/09/2021
NGINX | 01/20/2021
NGINX | 12/15/2015
NGINX | 01/01/2014
A Guide to Choosing an Ingress Controller, Part 4: NGINX Ingress Controller Options | F5
