What is MFA (Multi-Factor Authentication)?
MFA, or Multi-Factor Authentication, is a security authentication method that uses multiple factors to enhance security. The term "MFA" is derived from the first letters of "Multi-Factor Authentication."
By utilizing multiple factors, MFA creates layered authentication, significantly strengthening security.
MFA emerged to address the limitations of traditional password authentication. Even strong passwords can still be exploited through leaks, allowing unauthorized access. Furthermore, many users use guessable passwords, increasing vulnerability to hacking.
In modern times, where hacking techniques are increasingly sophisticated, the necessity of MFA continues to grow. MFA offers heightened security compared to traditional password authentication, protecting against risks like unauthorized access and attacks.
MFA’s primary disadvantage is the inconvenience for users during login processes for services or servers.
For instance, in commonly used two-factor authentication, users must enter a password and then input a verification code before logging in. This adds extra time and effort compared to password-only logins. In some cases, verification codes are sent to separate devices, causing inconvenience if the devices are not readily available.
MFA systems must balance security with user convenience to ensure a seamless authentication experience.
MFA is already widely adopted across many industries and institutions to enhance security.
