Causeway Capital Management to Simplify Deployment and Save Time with F5 NGINXaaS for Azure
Principals Sarah Ketterer and Harry Hartford founded Causeway Capital Management after pioneering international investment management in the 1990s. The firm’s 36 investment professionals pride themselves on combining quantitative and traditional approaches to the equity strategies they manage for institutions in North America, Europe, the Middle East, and Australia. Employees, who generally hold long tenures with Causeway and its clients, are the firm’s majority owners, which provides independence and commitment to putting client needs first.
Relationships are important at Causeway Capital Management, and the firm’s hybrid approach to investment analysis is based on a “best of both worlds” strategy. The collaborative concept also drives how the firm works with people and partners.
Similarly, the company is named after Northern Ireland’s iconic Giant’s Causeway, a geological formation of 40,000 interlocking basalt columns. Inspired by the durability of the Causeway, the firm’s approximately 100 employees value long, solid relationships that respect, leverage, and combine the various core competencies each brings – just as the individual basalt columns conjoin to create the Causeway. This focus on combining individual components into a greater whole is even reflected in the firm’s reliance on a cloud first, multi cloud hybrid strategy and Kubernetes based infrastructure.
Pete Petersen, the company’s chief technology officer and chief information security officer, says this culture extends to close engagement with vendors, who can essentially augment internal resources. “Really strong relationships give us a competitive advantage,” he says.
Business Challenge
One of those relationships has been Causeway’s partnership with F5 through NGINX. Petersen’s lean IT team – fewer than a dozen members – develops and deploys modern, container based applications. They began using F5 NGINX Plus in 2018 as a reverse proxy and Ingress controller for on premises applications, and as a web application firewall (WAF) to defend its website, including its proprietary Risk Lens analytics tool for clients.
When Causeway recently began using Microsoft Azure as its primary public cloud provider, Petersen wanted to leverage his team’s familiarity with NGINX Plus and the convenience of Software as a Service (SaaS). That is becoming possible with the development of F5 NGINXaaS for Azure, a tightly integrated Azure SaaS experience with bring-your-own-configuration (BYOC) flexibility.
“Being able to use NGINX as a platform service is very appealing,” says Petersen.
His team was so eager to use NGINX in managing their Azure deployed apps that they agreed to beta test NGINXaaS for Azure in a private preview.
Solutions
The Causeway team began working with NGINXaaS for Azure in phases. They started with a basic NGINX virtual server definition for handling HTTPS traffic, with the SSL/TLS certificate stored in Azure Key Vault. This server definition simply returned a 200 OK success code in response to browser requests.
Jake Diamond, DevOps and cloud engineer for Causeway, says, “Once we had proven out that basic functionality and become familiar with the interface, we added a little spice, standing up a back end service hosted by Azure Container Instances (ACI). At that point we were reverse proxying from the NGINX instance, and that was as simple as it had ever been.”
The final step in their private preview was a reference implementation of an OpenID Connect setup using the NGINX JavaScript (njs) scripting language to integrate Causeway’s Okta identity services. Diamond says, “That was taking the reference implementation we know and love in our current environment and seeing if we could do that in NGINXaaS for Azure.” This step, though a bit trickier, was resolved with support from the NGINX product team.
After this successful private preview, the Causeway team went live with NGINXaaS for Azure in their production environment after the product became available in the Azure Marketplace.
Results
Simplified app deployment across the data center and the Azure cloud
Petersen and Diamond are both pleased with the results of their testing, which included advanced NGINX traffic services with full lifecycle management through the Azure portal. Petersen says, “One of the goals was to see if we could use basically the same configuration techniques between the on premises stuff and the cloud stuff. And the answer was ‘yes’. The NGINX for Azure service had an ‘easy’ button on it. Having a lot of the same directives and configuration that we already know is super cool.”
Diamond adds, “You can’t beat a path service, especially one that is so tightly integrated with our primary public cloud platform. That is not available, to be blunt, in other public cloud platforms.”
The functionality is second to none. It’s far more maintainable, far more reliable, and has consistency that can’t be matched by standard or ‘roll your own’ software.
Jake Diamond, DevOps and cloud engineer, Causeway Capital Management
Time-saving configurability, observability, and ease
The Causeway team praises the solution’s configurability, due in part to NGINX extensions. “You can configure anything,” says Petersen. Diamond agrees that the available NGINX tools and out-of-the-box directives save a lot of time.
So does deep Azure integration that simplifies monitoring. “We can now get closer to that single pane of glass as it gets incorporated with all of our monitoring tools, such as Datadog,” Petersen says.
Petersen is also relieved that his team will be able to move forward with a proven product and a vendor he trusts. Otherwise, he says, “We’d have to start from zero, and it would take a year of playing with it before you could feel comfortable. Whereas I know NGINX is solid and it works and it’s performant, and I know you’re going to stand behind your product. I don’t have to regain that trust.”
He says NGINXaaS for Azure will “grease the skids” for other projects his team plans to tackle as they proceed on the company’s digital transformation journey.
“Without something like this, everything would get harder – a little more complex, a little more difficult, taking more training and staffing and integrations,” he says. “This will remove a little bit of friction for us. It’s going to unstick a lot of other projects, and our agility and velocity will only increase.”
NGINXaaS for Azure will remove a little bit of friction for us. It’s going to unstick a lot of other projects, and our agility and velocity will only increase.
Pete Petersen, CTO and CISO, Causeway Capital Management
“Second to none” support
“All throughout this process, the support was second to none,” says Diamond. “I really was impressed. I have dealt with a lot of support portals and vendors, and I can’t tell you the last time I had that level of support.”
Petersen laughs as he says, “We’re probably the smallest NGINX client on the planet, but you don’t treat us that way. You care, and it shows.”
The Causeway culture echoes when he adds, “Strong relationships are what make for success.”
See all customer stories
causeway-capital-management-to-simplify-deployment-and-save-time-logo
Benefits
  • Tight integration of data center and public cloud platform simplifies app deployment
  • Built-in configurability saves time, with easy dashboard monitoring
  • Strong commitment to support, even for small customers
Challenges
  • Causeway had used NGINX Plus as a reverse proxy, Ingress controller, and WAF since 2018
  • The company also began using Microsoft Azure as its primary public cloud provider
  • Causeway decided to beta test F5 NGINXaaS for Azure to determine the benefits of using NGINX to manage their Azure deployed apps
Products
Causeway Capital Management to Simplify Deployment and Save Time with F5 NGINXaaS for Azure | F5
