Build fast, secure data pipelines for AI training on AWS
F5 Ecosystem | August 13, 2025
You're investing heavily in AI models, training and tuning them for precise outcomes. But there's a critical bottleneck standing between you and optimal results: data ingestion. You need to move massive volumes of multimodal training data—text, images, audio, and video—from various storage locations to your AI models. If this process is inefficient, it can drive up costs and slow down training tasks. The challenge is that many traffic management solutions weren’t built to handle the dynamic nature of AI.
First, data sources are scattered across a hybrid multicloud environment, including on-premises data centers, private cloud storage, and edge locations. Moving terabytes or petabytes of training data from these diverse sources to your AI infrastructure creates complex traffic management scenarios and high data transfer costs.
Second, you're dealing with inefficient GPU utilization. When data ingestion becomes a bottleneck, your expensive GPU resources sit idle, resulting in higher operational costs and slower model training cycles. You need consistent, high-performance data streams to keep those GPUs working at full capacity.
Third, you must maintain security and compliance while moving valuable training data across networks. Your proprietary data is sensitive, from protected customer data to intellectual property that gives you a competitive advantage, and any security breach could be catastrophic for your business.
AI training with AWS
AWS provides a solid foundation for your AI training initiatives with services like Amazon SageMaker Pipelines for workflow orchestration, Amazon Data Firehose for real-time data streaming, and AWS Database Migration Service for ongoing data replication. These native AWS services handle essential data movement tasks and can scale to accommodate thousands of concurrent workflows.
“By combining F5 application delivery and security expertise with AWS AI development services, you can build data pipelines that are secure, efficient, and optimized for your specific needs.”
However, while AWS services excel at data ingestion and model training automation, you likely need capabilities that expand beyond AWS for complex scenarios involving hybrid multicloud environments, stringent security requirements, and high-performance traffic optimization.
F5 accelerates your success
This is where the F5 Application Delivery and Security Platform (ADSP) complements your AWS infrastructure with traffic management and secure multicloud networking to help you achieve your AI training goals more effectively.
Part of F5 ADSP, F5 BIG-IP Virtual Edition (VE) provides intelligent load balancing with TCP optimization specifically tuned for large data transfers to maximize GPU utilization. Features like server health monitoring and capacity-based routing ensure your GPUs receive consistent data streams, reducing costly idle time. SSL offloading combined with FastL4 and Fast HTTP profiles further accelerates data movement, helping you get more value from your hardware investments.
Also a part of F5’s platform, F5 Distributed Cloud Network Connect solves your hybrid multicloud connectivity challenges by providing secure layer 3 connectivity between your distributed data sources and AWS. You can connect on-premises and cloud-based storage directly to AWS with one-click provisioning, eliminating complex networking configurations. If you're using NetApp storage systems, F5 seamlessly integrates with multiple protocols, including Network File System (NFS), Server Message Block (SMB), and Amazon S3 APIs. Connect sources over the Internet, via a private backbone, or through the private F5 Global Network.
Increase security and control
F5 ADSP provides comprehensive protection for your training data across hybrid environments. You get distributed denial-of-service (DDoS) mitigation, web application and API protection, and full SSL/TLS inspection with centralized authentication and authorization. This ensures consistent security policies across all environments while meeting compliance requirements for sensitive data handling.
F5 traffic optimization features help you control both GPU and data transfer costs. Intelligent routing ensures efficient data movement between environments, while advanced compression and caching capabilities reduce bandwidth consumption. You can continuously monitor and optimize your data pipelines to prevent cost overruns, while maintaining performance.
Your path to AI success
By combining F5 application delivery and security capabilities with AWS AI development services, you can build data pipelines that are secure, efficient, and optimized for your specific needs. This integrated approach helps you:
  • Keep your GPUs consistently fed with training data
  • Reduce infrastructure costs through intelligent traffic management
  • Maintain security and compliance across hybrid environments
  • Scale your AI initiatives confidently as data volumes grow
A robust infrastructure that can reliably deliver massive amounts of data where and when they’re needed means your AI training initiatives are more likely to succeed in less time. With F5 and AWS working together, you can focus on developing innovative AI models while trusting that your data pipeline infrastructure will perform reliably, securely, and cost-effectively.
To learn more, visit the F5 on AWS overview page.
Also, stay tuned for our next blog in this series where we'll discuss protecting AI Innovation on AWS with API security.
F5 Ecosystem | 01/29/2026
F5 Ecosystem | 01/23/2026
F5 Ecosystem | 01/20/2026
F5 Ecosystem | 01/09/2026
F5 Ecosystem | 12/19/2025
F5 Ecosystem | 11/11/2025
