Modern application delivery isn’t just about keeping traffic flowing—it’s also about keeping traffic flowing securely across an increasingly distributed estate. Most organizations (93%) now run applications across multiple environments, with different teams, tools, and operational constraints. That reality makes unified observability extremely difficult.
Adding to that challenge is new pressure that changes the day-to-day calculus for operations: frontier AI.
Frontier AI models—like Claude Mythos—are accelerating vulnerability discovery, helping vendors enhance products, and improving customer outcomes. They’re also accelerating exploit development, compressing the time between “issue found” and “issue exploited” from weeks to hours (and in some cases, before broad public disclosure). But even with the faster discovery of vulnerabilities, organizations still need validation cycles to patch safely. That creates an unavoidable exposure window—the period when a vulnerability, misconfiguration, or weakness remains exploitable even after it’s known.
Why fleet management
F5 Insight for ADSP is the foundation for cross-functional visibility within the F5 Application Delivery and Security Platform—delivering unified, near real-time observability across applications, BIG-IP services, and supporting infrastructure. F5 Insight brings together advanced analytics, proactive alerting, AI-driven operational narratives (via MCP and an LLM of your choice), and helpful guidance that puts an F5 expert in your stack.
F5 Insight already helps teams answer questions like:
- What’s happening across my apps, services, and infrastructure right now
- Where are anomalies emerging?
- Which policies are driving risk or performance impact?
- What should my team do next?
With v1.2 of F5 Insight for ADSP, we’re adding the ability to act on one of the most operationally painful yet security-critical workstreams in the enterprise: keeping fleets current and hardened through updates and patching—a big operational necessity for enterprise-scale organizations.
Software lifecycle management for BIG-IP updates
F5 Insight v1.2 introduces central software lifecycle management designed for large-scale enterprise realities: more frequent change windows, more change per window, and less time to execute.
In v1.2, the management functionality is focused on both minor and patch-version BIG-IP updates. In other words, this is about keeping BIG-IP current through an ongoing release cadence—for example, moving between supported minor/patch trains—rather than orchestrating major-version upgrades.
This initial fleet management delivery follows a consistent loop: See the signal → understand the context → run the action.
What you can do with fleet management in v1.2
Here are four ways your organization can use fleet management:
1. Run minor/patch BIG-IP updates with guided workflows. Fleet Management in F5 Insight v1.2 helps teams confidently stage, validate, and execute minor and patch BIG-IP software updates across a BIG-IP fleet. This initial use case reduces significant operational overhead and the reliance on bespoke scripts, manual runbooks, or device-by-device processes.
In the context of enterprise operations, that matters because the hardest part isn’t downloading an image; it’s safely executing changes repeatedly across dozens (or hundreds) of systems without introducing downtime or configuration drift.
2. Execute updates in batches to fit smaller maintenance windows. Thanks to frontier AI, teams can find more vulnerabilities faster—but so can bad actors. That means patch windows are shrinking, ops teams are racing against the clock, and the number of required changes per window is increasing.
F5 Insight v1.2 includes support for:
- Custom jobs and batches for updating instances
- Serial or parallel execution
- Pausing updates jobs to ensure things run smoothly
- Pre and post checks
These controls help teams fit more updates into smaller windows, while still maintaining disciplined verification and the ability to slow down or stop when needed.
3. Update more devices in parallel. One of the biggest levers for completing change faster is parallelism. Based on the v1.2 fleet management target, F5 Insight supports running update jobs at scale—up to 100 instances per job—with batching and parallel distribution options to improve change window efficiency (timing will vary by environment, configuration, and policy footprint).
The update workflows also support updating and patching devices sequentially as well as in parallel. In short, we want to meet our customers where they are and align to their needs and ways of working.
4. Support high-availability patterns and common deployment models. Fleet management in v1.2 is built for real-world BIG-IP estates. For example, our internal research has shown that most of our customers deploy BIG-IP devices in high-availability pairs. F5 Insight for ADSP v1.2 supports key operational patterns such as:
- Rolling and batch approaches
- Active/standby or standalone deployments
- Support across VE/tenants and iSeries/rSeries environments
In today’s security and operations environment, Frontier AI compresses exploit timelines, validation cycles remain, and the exposure window persists. So, the operational question becomes: How quickly can you apply the fix safely across the fleet?
F5 Insight v1.2 helps answer that by pairing unified observability with guided fleet execution for minor/patch updates, so teams can reduce time-to-remediation without trading away control.
Access controls, auditability, and resilience
Scaling operational change entails more than speed; it also requires enterprise-grade controls to ensure change is safe, traceable, and defensible. F5 Insight v1.2 also introduces critical new features that help teams ensure operational excellence and enterprise best practices.
F5 Insight includes enterprise-ready access controls, including fine grained role-based access control (RBAC) and SAML SSO support. This reduces identity friction, aligns F5 Insight access with enterprise identity providers (IdPs), and supports least privilege access across visibility and operational workflows.
For RBAC, users can be either administrators, operators, or viewers. Each of these roles has further access granularity that ensures the right people have the right level of visibility and permissions.
F5 Insight’s MCP support enables natural language interactions with your telemetry using a supported LLM of your choice (any that integrate with OpenAI API). As customers adopt AI-assisted operations, they need auditability and accountability.
F5 Insight v1.2 introduces enterprise governance features, including AI agent history and auditing, AI per-user chat history (24H), and AI audit log viewer.
These capabilities help teams review AI-assisted interactions and support incident response and governance workflows.
Operational response also includes operational resilience. In v1.2, F5 Insight introduces simple, streamlined backup and restore workflows directly within the F5 Insight UI.
The system backups ensure that in the event of an outage, failure, or other disaster, teams can get visibility and fleet management back up and running again quickly. The backup workflows extend to several key aspects of the product including insight configuration, dashboards, and stored telemetry data.
Where this fits in the bigger operational story
F5 protects applications in the data path with inline enforcement and application delivery and security controls. As organizations absorb faster hardened release cadences in a frontier AI threat landscape, they need to keep BIG-IP estates current without increasing operational risk.
F5 Insight v1.2 helps operationalize that reality by combining:
- Unified observability across application and infrastructure layers
- AI-driven operational narratives that turn telemetry into action plans (via MCP + your LLM)
- Fleet software lifecycle workflows for minor/patch BIG-IP updates and patching efficiency
- Enterprise access controls, AI auditability, and backup/restore for resilience
To learn more, read our press release and visit our F5 Insight for ADSP webpage.
You can also explore the latest release of F5 Insight in more detail by joining us on July 30 for a live webinar, ”Transforming BIG-IP Operations: How F5 Insight for ADSP Updates Improve Visibility, Security, and Scalability.” We’ll explore use cases and functionality—and show you the latest enhancements in a deep-dive demo.
About the Author
Securing F5 NGINX in the age of AI
How F5 is applying AI-driven security practices across the F5 NGINX portfolio to help deliver safer, more resilient software.
From dashboard fatigue to operational excellence: Why XOps needs F5 Insight for ADSP
Learn how F5 Insight for ADSP lays the visibility foundation for XOps—turning fragmented signals across applications and infrastructure into actionable intelligence.
The hidden cost of unmanaged AI infrastructure
AI platforms don’t lose value because of models. They lose value because of instability. See how intelligent traffic management improves token throughput while protecting expensive GPU infrastructure.
Govern your AI present and anticipate your AI future
Learn from our field CISO, Chuck Herrin, how to prepare for the new challenge of securing AI models and agents.
F5 recognized as one of the Emerging Visionaries in the Emerging Market Quadrant of the 2025 Gartner® Innovation Guide for Generative AI Engineering
We’re excited to share that F5 has been recognized in 2025 Gartner Emerging Market Quadrant(eMQ) for Generative AI Engineering.
Self-Hosting vs. Models-as-a-Service: The Runtime Security Tradeoff
As GenAI systems continue to move from experimental pilots to enterprise-wide deployments, one architectural choice carries significant weight: how will your organization deploy runtime-based capabilities?
